C200 goblin
Does anyone know what the big black relay type boxunder the fusebox in a W202 c200 is. It is around 15 cm long by around 10 cm high and screwed on by two torx screws.
It has the part numbers;
019 545 56 32 [SAM] onto it. ALso TEMIC 304-587
Also what are the relays on this car I need to knowwhat circuits they control. They are;
A - Black
B - Green,when I shake this it sounds like it has a lil stone shaking in it
C - Yellow
D - Yellow
F - Black
My cooling fan still goes off from the moment the ignition is turned on and stays on permanently until turned off. I did what I saw in another thread and cleaned the wiring etc,but no success and there wasnt any signs of water damage in both fan control modules (old and new one).
Everything is replaced, apart from the relays as I do not know what relays control them.
My chassis is WDB2020202F825895
BTW does anyone know what the unit behind the front nearside passenger footwelland mounted to the metalplate wall is. It has the numbers A 024 545 80 32 with SIEMENS 5WK33810F
A - Black
C - Yellow
D - Yellow
F - Black
