C200 fuel consumption
bigjobby01
Guys, I have a 1997 C200 5 speed auto, the MPG I am getting around town seems poor, under 20mpg. Although on a decent run it almost doubles. From a full tank of fuel I get around 220 miles. Does this seem excessive? Most of my driving is around town. I used to just leave it in D, but recently have been using 3 & 4 in traffic. Is this MPG about right for the age of the car around town?
Cheers
Hibbo
East Scotchland
Good username my son!
Is your gearbox in S or W (or E or S or whatever it has?) (how about that for or repetition):)
eric242340
Banned
China
I dont see the relevence to this post? Am i confused or what?:confused:
eric242340
Banned
China
Hi Hibbo, I see you are on line. Can you enlighten me on your thinking here, thanks?
bigjobby01
bigjobby01
I have been keeping it in S.
It does not make much difference in S or W, to be truthful if there is no black smoke comming out of the back,then nothing is wrong.
The most efficiant running temperture is 100c,if the engine is not getting this warm that could be the problem.
Malcolm
Hibbo
East Scotchland
I thought that it holds the gears longer in S, thus MPG would suffer around town.
They only hold the gears when cold,no holding when warm,that applies to W or S start
The position of the throtle is directly related as to when the box will shift up
so at light throttle openings it will change up as soon as possible.
Malcolm
bigjobby01
bigjobby01
Temp seems OK. No smoke, servicing OK. I'll try it in W for a while and see if it make any difference. I only average 6000 mile per year most of which is around town, to & from work. Does anyone think <20MPG is OK?
type49
20 is a bit poor for a C200. I bought one, a 99 C200 5speed auto, I don't drive it much as it is for my better half. She drives "normally" but only a few miles + in traffic but still does about 300 miles on a tank (about 55 litres to fill up - not completely empty). This works out about 24.8 MPG. I took it to Devon & got about 360 from a tank, not going over 90 (sorry officer).
You should have dropped in for coffee.
malcolm
Hibbo
East Scotchland
Malcolm
Righto, my mistake. I've never driven one as old diesels don't have this switch!
I was under the misapprehension that it (the switch) affected the shift points for a given throttle opening.
Every day is a school day! :)
There is nothing wrong with your post, Electronic boxes with lock up did not start till 97 ish, and there was no lock up bere that unless you engaged 1-2
Keep posting,it make me think.
Malcolm
www.ckinsurance.co.uk
