c200 not starting
clelly
I have a c200 (w202) w plate 2000. car has been running great untill this morning,now it wont start. The weather last night was wet with very strong winds,and my car was sitting well exposed. The car is turning over fine,but just not catching,does anyone have any suggestions?
thanks
Xtractorfan
S class
The Cps comes to mind .. Crankcase position sensor..doubt if the weather would cause your problem, cars are built to drive in bad weather..
roofless
w124 e220 estate
do you have a immobiliser ?
Cole@MBS
www.mbssouthampton.co.uk
Been thinking the same, thats the first thing to look at!
C
clelly
An immobiliser is fitted as standard although that wasnt on last night as the car wasnt locked.(think the immobiliser only comes on if car locked) Its very strange engine is turning over although it does sound a bit rough.
C
clelly
Where abouts are the cps are these easy to replace
CPS do fail either when very cold or very hot,, the expansion and contraction breaks the wires
R
recycledjuvenile
if it is petrol it could be the coil. it will just turn over but will not fire
Cole@MBS
You didnt move the car a small distance the day before did you, it could be flooded!!!
C
clelly
dont think its flooded ive tried to start the engine quite a few times today i`d have thought that would have cleared it
Cole@MBS
Going to have to sign off soon, if the above is correct then remove the fuel pump relay next to the battery in the boot, crank over until it starts and cuts out, replace the relay and it should start???
roofless
w124 e220 estate
if you turn the ignition on not start can you hear the fuel pump a buzzing sound for a few secs
C
clelly
yea fuel pump definately buzzing
C
clelly
Will give it a try
roofless
w124 e220 estate
might sound daft but immobilise lock it then open & try .did this midweek with a mates car & it worked?
C
clelly
  • #18
Hi just tried this but made no difference
