C207 BOOT WON'T OPEN ELECTRONICALLY ?
NomadTrucker
EClass 2015 220
Hi Everyone
Boot was working yesterday by pressing the button on the key for the boot and by pulling the button in the drivers door.
Today it won't work electronically only by using the long metal key within the car key so doing it manually.
I've looked online and it says fuse slot 61 has a fuse for the boot electronics or somthing to that effect but there is no fuse in slot 61. Maybe I'm looking at the wrong user manual ?
Any ideas please. Thank you
onefortheroad
uk.
Me -2019 GLC 350 coupe AMG line. Mrs- 1.2 vauxhall Corsa 2021 ,orange with a black roof. .
40 amp in the boot , fuse 61 .
N
NomadTrucker
EClass 2015 220
So how was it working without a fuse in the slot previously because it wasn't there before so if I put one in it should work again ?
onefortheroad
uk.
Have a look in your fusebox , there's usually a paper diagram of the fuses. I'll check my c207 user manual and report back.
N
NomadTrucker
EClass 2015 220
I'll have another look tonight... Its the fuse box in the boot with slot 61 - Didn't see one when I looked earlier
Srdl
Hampshire
GLC43 AMG 2018 (X253)
Fuses 39, 41 and 62 also seem to cover Rear Control Unit depending on exact model?
  • C207 N10-2 fuse & relay assignments 2.pdf
