C209 CLK won't start when warm
bob11
NE London
CLK 220 CDI 2009
Hi all,
I have CLK 220 CDI 2009 that doesn't want to start when it's warm outside, about 15 C degrees or when I drove it enough for the engine to warm up to regular temperature.
All dashboard lights appear as normal, except for the engine management light which doesn't appear at all and the displays says "Run flat indicator inoperative".
If the engine cools down and it's less than 14-15 C degrees outside, the car starts normally.
I scanned the error codes with an iCarsoft MB v2.0 with the engine on, just after I started it and again when it doesn't start (with the key on).
I used the auto scan feature.
On the second scan the scanner is not seeing the ECM module anymore.
I did the following:
- start the car
- auto scan, scanner shows 17 modules
- record all error codes, except for the ECM, TCM and ESM. I delete the errors for these before recording them, like an idiot.
- delete all error codes
- driver the car for 20 min to warm engine
- stop car
- try to start car, it does want to start with symptoms describe above
- auto scan with key on, scanner shows 16 modules (ECM missing)
Do you think there is anything that an amateur like me can try to determine the cause of this or fix it ?
And does anyone know a Mercedes specialist around north east London that works in this period ?
B
bob11
NE London
CLK 220 CDI 2009
  • #2
Sorry, I got the dashboard light name wrong, it's not the engine management light, but the coil shaped (attached picture) one that is not turning on when i turn the key and the car won't start.
B
bob11
NE London
CLK 220 CDI 2009
And these are all the error codes that I get on the second scan (when the car won't start):
ECM: not showing at all.
ESP:
C1038 1/2
State: Current
Engine control module not identified or incorrect control module
C1022 2/2
State: Current
CAN communication with the engine system is faulty
IC:
B1102 1/1
State: Current
Fault in CAN communication with control module ME-SFI
SAM_F:
B1036 1/1
State: Current
The input signal'circuit 61'is not o, k
SAM_R:
B1078 1/1
State: Current
Fault in communication with component H3/1(Alarm signal siren with additional battery) or there is a cable fault
TCM:
P2311 1/2
State: Current
One or more messages from the engine control module are not available on the CAN bus, (CAN timeout fault)
P2312 2/2
State: Current
grahamcol
West Midlands
2001 SLK230, 2007 CLK220 CDI
You have the same car as me and I'll be interested in hearing how this gets resolved in case it ever happens to me. I know the petrol models can be prone to cutting out / difficult to start when hot and that's caused by the crankshaft position sensor. I'm unsure whether that also applies to diesel models. Good luck with this.
Hi all,
- start the car
- stop car
Wayne Gates , Harrow , don’t know if he’s open ?
RR007
CLK W209 2005 220CDI
I have the exact same issue as - bob11 CLK 220 CDI 2005.
Same error codes on the scanner. Did you manage to find what the issue is -
I know its an old issue. hope some will answer
