C220 Cdi 2009 estate , problem with abs traction control and run flat inoperative
Stephen Forster
Registered
C220 Cdi estate 2009 blue efficiency automatic
Hi guys , had warning lights come up ,Traction control, abs, run flat inoperative and no cruise
Had car scanned
Came up with no wheel speed signal coming from resr os. Had speed sensor changed but problem still there . Any ideas ??
umblecumbuz
Wales and Gozo
Presumably you don't have your own scanner?
Is it possible to take live wheel speed sensor readings? If so, this might give you better info.
Sometimes the plug to the wheel speed sensor, under the wheel arch, can have poor connection. Worth checking.
Do you have an esp light on?
JohnnySBC
London
www.ecu-repair.co.uk
W212 E350 - Remapped --->>> 300 bhp
Had car scanned
It could be the pickup ring , where the sensor is reading from , 2 it could be wiring or 3 it could be the ABS ecu ( unlikely )
BR
star
Reading
Smart + others :)
Genuine part or aftermarket? Known aftermarket not to work as slightly different length.
John Laidlaw
Wirral
Land Rover Discovery 4
Dual post Ian, he said elsewhere he used aftermarket so I reminded him of the error of his ways....
E280 CDI 2009
Had car scanned
just had the same on my E280 CDI W211 09 today took it into Autoklass and diagnostics ECU malfuction - apparently these systems are on the same system - replace part
That sounds expensive buddy ?
I'd be getting a second opinion...
