I have a new battery fitted by MB. If I don't drive the car for 3-4 days, the battery is completely drained of power and requires a jump start. This has happened 4 times in last 6 months. MB / AA checked the battery and alternator etc and all is well. No problem is detected when the car is used everyday.
I have just had a full electronic diagnostic check done over 2 days and the finding is that the battery is using 7amps (should be 3amp max) of power after the engine has been switched off completely, but no one is able to identify which component is causing this.
Has anyone experienced similar problem ? Any suggestions where the problem may lie ? I have Command system and there are no fault messages to provide any clue. MB with all their diagnostic capabilities and knowledge base can not help !!
Any help / suggestion - most welcome
