I have had this problem before and we replaced the 'crank shaft sensor'. Car has been ok for two weeks but would not start this morning. Is there a sensor on the Cam Shaft that could be the cause of the problem?
Sounds like you have an injector leaking off too much or faulty high pressure pump. If no faults on star then you have to start with actual values looking at fuel pressure etc. I would chuck some easy start up the air intake whilst cranking, if it goes then chances are you have a faulty injector.
Following the replacement of the CPS it ran perfectly, till I tried to start it this morning. Surely its unlikely to be an injector - which were all replaced last year. I will try some easy start never the less in the morning.
The CPS does often fail when engine hot but I see no reason whey the opposite could not be true If you have a ohmmeter you could measure the resistance where it should be 1 k ohm when good and near on infinity when bad.
£47 from any Bosch service center £87 from MB
Steve, thinking about this problem at bit further.
The problem has only occurred in sub zero temperatures.
Both times this problems happened:
The Car started instantaneously only to stop 4 seconds or so later. Whilst it was running it was running smoothly ie with good ignition on all cylinders.
It therefore cannot be any of the following:
Bad compression
Glow Plugs
Pressure in the common rail.
Is there anyway that water frozen in the fuel lines could be a culprit?
Is it likely that the new CPS is faulty? surely these things should not be affected by the cold?
Any idea gratefully received. - I wont go near our local Merc dealer since they tried to rip me off after a "health Check" - quite disgraceful it was too.
Bad compression
Glow Plugs
I stand corrected!
How much fuel is in the fuel tank?
Just under half: She will run for miles on an empty tank - I've tried!
Just chipping in a bit,,it is mainly the O rings that need to be replaced, not so easy when it is this cold as everything is so hard and stiff, the pipes should all be OK
