Greensquare
- Oct 15, 2021
- Mercedes C220 CDI Estate 2003
Hi All
I have an issue which is driving me crazy!!, My car started getting hard to start and i had to crank it for longer and longer, it was also smoking quite badly when throttle was applied (dark grey smoke). It now won't start at all, I noticed no fuel was going from the fuel filter along the clear low pressure line to the high pressure fuel pump. After spending many days searching the forums for possible solutions here is what i have done so far............. Had the injectors checked they are ok, changed all the low pressure fuel lines and o rings for new ones, fitted a reconditioned high pressure fuel pump, the one above it is working ok, filled the tank with fuel as my car does not have an electric pump in the tank, changed the fuel filter, checked there is no blockage on the fuel line from the tank by pumping fuel out of the filter feed hose. Having tried all of this and some good advice was given on here it still refuses to start, no fuel leaves the filter when turning the car over, i even by-passed the filter and still nothing. I have tried to bleed the system manually and bubbles appear in the feed pipe from the filter going back into he filter.
Does anyone have any ideas before i tow it to a secluded spot and happily set fire to the ****** thing!!!! it would be a shame as it has served me well for 3 years, its always serviced every 10000 miles and goes through the mot each year without a problem and has covered 135000 miles.
Please Help1
Dan
Please Help1
Dan
