faisalamir50
- Jun 24, 2008
Hi i have posted before about this car, in first the car wasn't even starting when it started there was large knocking noises and a lot of smoke after that, i found out that the injector in 4th cylinder was leaking, i got it replaced from a merc specialist and conrod was bent so i got it changed from someone not far from my house, ex mechanic, most of the knocking noise went away and so did the white smoke, now it is still knocking, and there is still some lack of power, i replaced the maf it is better but knocking has still not gone away, and knocks even more when under load and still low on power, i think it might be one of the following and need help:
1) Might be another injector but not coming up on OBD2 so how do i check it
2) Might be a Bent Valve but how do i know and check
3) The mechanic never replaced the sheels in the conrod, can it be it and how do i know
4) Might be a Piston problem as when i rev the engine fast i get some blue smoke
5) Last one could it be simply a knock sensor, how do i check it and where is it
Can some please get back to me thanks
