Greensquare
- Oct 15, 2021
- Mercedes C220 CDI Estate 2003
Hi All
I am having trouble getting my Mercedes to Start, it started getting hard to start and took longer and longer turning over before it would eventually fire up, when driving it was getting really smokey from the exhaust when you put your foot down ( Dark Grey in colour) then the starting motor packed up, had that changed along with number 4 injector as this had failed and was causing the starting issues or so i thought. Since i did the work the car has started 4 times and ran really well and no smoke but now won't start at all, i have checked the leak off on the injectors when cranking the car and they seem ok with minimal fuel coming out of them. It does not have the fuel pump in the tank on this model and the only thing i can notice when trying to find the fault is low pressure fuel going to number 4 from the fuel rail, when i loosen the nuts on the rest of injector feed lines fuel squirts out ok. Does anyone have any suggestions on how i can fix this problem ?
The car has covered 135000 miles and has full service history, it too good to scrap !!
