c220 diesel fuel lines.
Rappey69
hants
c220 w204 amg sport
Have changed the plastic lines under the bonnet and car has been cranked for england and still no sign of life.
Have battery charger on so every 2 hrs have a cranking session then leave for battery to recharge.
My question is this- the high pressure pump (one on the front end of engine) has 2 plastic fuel lines on the lower lhs of it. not sure if i have them the wrong way around?? (doh) so one leads to the far end of the common rail, and the other (one with a "T" in it) goes to/from the pre-delivery pump 1.(upper or lower hole?) 2. which one is nearest/furtherest on high pressure pump?
Have consulted russian site and haynes manual but bit inconclusive.
Cole@MBS
www.mbssouthampton.co.uk
Swap the around and get someone to see if the fuel starts to run though the clear lines.
I have put them on the wrong way once!!!
Rappey69
Rappey69
hants
c220 w204 amg sport
And whilst im at it, the pipe with a T in it has a bleed valve? at the end of it, do i need to do anything with it?
www.ckinsurance.co.uk
