C220 w204
Shieldsy
C220 amg w204
Morning peaple,hope somebody can help me on here,I have a 2013 c220 w204,having major issues with fault code P010315 mass air flow sensor 1 has a short circuit to positive.there is a short circuit to positive or a open circuit.ive changed the maf sensor,still the same,and I've also changed the EGR,its getting very expensive now and still the same,can anybody please help me
Shieldsy
C220 amg w204
  • #2
Morning peaple,hope somebody can help me on here,Ihave a 2013 c220 w204,having major issues with fault code P010315 mass air flow sensor 1 has a short circuit to positive.there is a short circuit to positive or a open circuit.ive changed the maf sensor,still the same,and I've also changed the EGR,its getting very expensive now and still the same,can anybody please help me
Shieldsy
C220 amg w204
Hello and welcome,
I've merged your threads and moved them to the technical section. There's no need to post the same question across multiple forum areas, it just leads to confusion for members with replies.
Shieldsy
C220 amg w204
Thankyou.sorry for troubling you.so my thread is active on here? Wish somebody could help me
Steve@Avantgarde
Bristol/Somerset
The engine has probably gotten an air leak so its air mass is incorrect, so it pulls its signal. I think you are probably chasing the fault code rather than the values from the engine.
Shieldsy
C220 amg w204
Thanks for your reply steve,I've checked engine pipes for air leak but cant find anything,really frustrating me,cost me over £1000 and still the same,engine light is on throwing that fault.if I start the car and drive away it drags through gears at high revs,if I start the car and let it run for 5 seconds then switch off and instantly restart it drives great even though engine light is still on?
Steve@Avantgarde
Bristol/Somerset
Without the car its difficult to say what it might be. Find a MB specialist with Xentry would be the best advice I can give. But as a clue, I've never replaced air mass meters on the 651 engine for any fault!
Shieldsy
C220 amg w204
Thought my engine was a w204?
C220 2009 2.1
Yes going through the same problem for the last few months. My mechanic has now said it’s the swirl valve in the manifold. We have changed the mass air flow sensor the EGR valve, the ECU so hopefully it’s the swirl valve.
Shieldsy
C220 amg w204
Does yours do the same as mine?if you start the car and drive it it drags through the gears like 2500 before gear change? But if you start the car leave it to idle for 5 seconds,switch of then straight back on drives great
umblecumbuz
Wales and Gozo
The C class 204's started with the 646 cdi engine, and 'graduated' to the 651 engine.
Your's being 2013 will have the 651 engine.
Shieldsy
C220 amg w204
When are you changing the swirl flaps eddie
Shieldsy
C220 amg w204
Cheers Cumbuz usefull info buddy
C220 2009 2.1
It’s hard to explain best thing is to call me on 07914094686 and we can chat
Shieldsy
C220 amg w204
  • #18
Hi Eddie any joy after you changed your swirl flaps
K83
New Registration
C class
I’m in a similar situation. I’ve had my air flow sensor changed but EML still on but this time with DPF issue. Mechanic thinks it’s clogged up. Any suggestions, greatly appreciated.
K
