C220 wiper fault.
shawkerr
The wipers on my 2001 C220 cdi will not operate on startup until I reach 5mph, and stop wherever when I stop. I've been told that I need a new wiper motor complete. Any advice please.
shawkerr
Hello and welcome,, what an odd fault to have,, I do not see why it wants a motor though
Ultymate
N. Wales
C230K Estate 1998
Sounds like something on the wiper linkage is siezing up and when you get the extra voltage from your alternator they work then when you stop the voltage will drop slightly causing the wipers to stop also.
I think the above is a very good answer,, have a look in the DIY section on how to oil it
Ultymate
N. Wales
C230K Estate 1998
Is it a single or double wiper on the 203 Malcolm?
Silver-racer
N Wales
'02 C220CDI SC + '02 SLK200K, now gone '07 CLK 220cdi + 57 A160 cdi both gone, into 09 C250 cdi w204
wiper motor
I had a c220 cdi SC, and I believe that is correct operation for the wipers, it's so it doesn't operate on a dry window, especially when you are travelling in a queue.
Gerry
N Wales
'02 220CDI SC (gone, part ex too good to refuse)
'07 CLK 220 cdi elegance with all goodies
'02 SLK 200 (plaything)
ernieh
Scotland, East
203 Wipers
Unless I'm missing something, this is the correct operation for these wipers when rain sensors are not fitted. Below approx 5MPH, they drop a 'notch'; i.e. from Inter to Off; from Slow to Inter, etc., and revert to setting when car starts to move.
With rain sensors something similar happens, except that Intermittent becomes almost non-existent. Sometimes I find that its better to press the button for a manual wipe.
Hope this helps.
Ernie
shawkerr
Thanks for the reply.
Wipers work when vehicle moves above approx 5mph, irrespective of engine revs!!!
ernieh
Scotland, East
Speed Related Operations
There are a number of speed related operations on MBs, to name but three:
wipers, seat-belt warning, auto-locking and maybe more. Hope this helps.
Ernie
shawkerr
shawkerr
Gerry
N Wales
In normal operation, on starting up the wipers can be operated before the car is in motion, one must be able to see through the windscreen. At the moment the wipers will not operate until approx 5mph is reached. Normal operation when one stops at traffic lights etc, is for the wipers to park after perhaps one sweep, at the moment they stop wherever they the instant the car is stationary!
Shawkerr
shawkerr
Thanks, but it occurs irrespective of engine revs!!
Shawkerr
whitenemesis
CLS55 AMG '05
When stationary do the wipers give a single wipe when you press the stalk? If they do it would rule out a linkage problem.
The wipers will not operate if either front door or window is open. Do you routinely open you window at start-up? This function cancels at speeds above ~5mph.
