C230 1997 C36 front Spoiler removal
ds24215605
Lancashire
Mercedes C-230 Sport Auto
Anyone any guidance on removal of front spoiler. Its had a slight bump N/S and is hanging down slightly.
Any help appreciated.
To 06-97
m.mycat
07-97 and on
m.mycat
ds24215605
ds24215605
Lancashire
Many thanks, much appreciated, is there anything i need to be cautious of when removing? Are they simple to take off?
Probably best to take the whole bumper off and then take it apart, I can send you the details for the basic 202 bumper that will be something like the same
ds24215605
ds24215605
Lancashire
OK, many thanks, is there any connections to the airbag i need to be aware of?
Nothing there at all just unbolt it
bigasotonuk
Southampton UK
C43/55 AMG 1999 / C230K 1997
From memory you will need to remove four bolts from the front of the bumper, two above the bumper can be seen with the bonnet open between the headlights, and two below them access through the removeable bumper inserts, the sides are clipped on, to unclip the bumper at the sides you will need to remove the forward most wheel arch liner on both sides to expose the clip fixings. If as you say the bumper hanging slightly on one side it is likely that this clip is broken or the metal bracket that secures it to the body is broken/corroded.
Don,t forget to disconnect the outside temp. sensor (if fitted) and unplug the foglights when removing the bumper otherwise you could damage the looms. These looms can corrode, and become brittle so you might want to observe care.
bigasotonuk
Southampton UK
Just found this "HOW TO" though its not quite the same bumper but it does show exactly where the four mounting bolts of the bumper are as the location of these never changed.
Credit for this "HOW TO" goes to KillerHertz, for a very informative and simple to follow set of instructions.
http://www.mbclub.co.uk/forums/howt...-front-bumper-fogs-w202-not-56k-friendly.html
But that means he has to join to see the link,,, it easier for me to email the works sheet on removing it if he needs it
bigasotonuk
Southampton UK
Well hes now got the choice of doing either or both :D,
Though to be honest I did,nt think you had to be logged into the forum to see the thread, my mistake.
ds24215605
ds24215605
Lancashire
Many thanks, the info recd is extremely helpful, i will let you know how i get on. As you say i presume its just a broken clip.
again,
many thanks.
ds24215605
ds24215605
Lancashire
Removed bumper just on NS so i could see the offending part.
The rubber (179 on diagram) had somehow worked loose and dropped. Refitted into slot and bolted back up securely - fitted some new bolts as a precaution - job done.
Many thanks for advice, once again this forum and the members knowledge has prob saved me a tidy amount of money and time.
Great.
Great.
A nice post :D:D:D
