The gearbox was "sealed for life" unfortunately some started to fail within the warranty period so Mercedes now recommend a one off ATF change at 40K miles. Yours should have a drain plug on the torque converter so you should be able to change all ~7ltrs of ATF. There is a "how to" guide in the DIY section if you're that way inclined.
