C240 low idle
bc100
South Devon
S205 C250 BluTec Estate 2014
I have an slightly low idle on my 2001 C240 that occasionaly feels as though it might stall. Is this a simple adjustment?
grahamcol
West Midlands
2001 SLK230, 2007 CLK220 CDI
My understanding is that the idle speed is controlled by the ECU and that it is fixed. However something's causing the low idle speed. Maybe the car needs a star diagnostic to help establish the cause.
Good luck with it.
Could need a throttle body clean and adaption reset.
B
bc100
South Devon
Reading further, some people have seen this behaviour linked with accelaration hesitancy which I also have from time to time. This could be due to a MAF sensor fault.
Star would be good but I don't know a local garage that does just a star diagnostic. I have been going to Avantgarde but it is a long way for something that isn't too serious.
Ah yes, if you also have drive ability issues, then I would suspect the MAF. If its not bugging you then maybe wait until you have a service due and go to Avantgarde?
B
bc100
South Devon
Is it worth trying to clean it, assuming its dirty of course?
AnthonyUK
Alton, Hants
C240 estate 2002
A simple check is to ensure the engine cover/filter housing is sitting correctly on the MAF. I had this once after changing the air filters.
B
bc100
South Devon
I'll have a quick look in the morning and report back. Thanks all for speedy replies.
B
bc100
South Devon
I too would suspect the MAF. Nothing to adjust on these engines, but not a lot that controls its running values other than the MAFs either.
So just buy a new MAF then? I'd pop up Steve, but as you know I'm a long way away unless I'm on my way to Bristol.
Steve@Avantgarde
Bristol/Somerset
I would still STAR test it, otherwise its nothing more than a best guess. If you are going to replace the MAF, make sure it is a Bosch unit.
www.ckinsurance.co.uk
