CMR
Twice now my display has showed ‘Undervoltage - Switch off consumables’. Once when I had the wipers and side lights on in heavy rain. Switching these off at the time would have meant no longer being able to drive the car! The second time was with just the cd/radio on (which I suppose I live without but I didn’t think they draw much current). Does this mean I should trickle charge the battery? (ie Disconnect overnight and charge)?
Background info: Car C240 Y Reg. New battery fitted July 2006 just prior to my purchase of it. Only electrical alteration was ‘after market’ alarm disconnected since its was going off every time I unlocked the doors. Usage: Only used weekends. Mostly short journeys (10-40miles), occasional once a month long journey (300 miles inc.)
My real concern is what I have read in previous posts where damage has been done when disconnecting/connecting the battery (see below Title W203 C240 strange warning message) and so I’m pretty concerned what I should do. Any help would be much appreciated!
Quote as previously posted:
"Did you replace the battery yourself? I know of someone who disconnected their battery on a W203 and when reconnecting found the same problems as you, wipers, indicators etc. were not working. They took it to the dealer and it transpired that the SAM module had burnt out when the battery was reconnected. This is a well known thing apparently."
Posted reply
If the battery change can cause damage, I would like to understand what additional measures need to be taken to ensure that SAM damage does not occur.
Unfortunately the reply then says
Its a guy called mobeyone on the 'other' forum (mbclub.co.uk) There's a thread about it. I wont post the link here though.
So could anyone help re: the above and what are the risks to damaging the SAM unit if I have to charge the battery (assuming that is I have to charge battery to stop warning message)?
Many thanks for any help
Posted reply
