Will Ashman
- Feb 26, 2019
- C250 2013 2.2 diesel
hello guys, week ago fault began with my c250 2013 bringing the engine management light on and causing the car to judder/ severe loss of power and then into limp home. Had car plugged in...
P023628 - the boost pressure sensor has a malfunction. The signal offset is outside permissible range.
P029900 - the boost pressure sensor of turbo 1 deviates from the specified value at low engine speed.
I replaced the boost pressure sensor but the fault is still there. I then had this fault code after a few days
P227962 - a leak was detected in the intake air system. The signal comparison is faulty.
I have had a good look around all visible boost pipes and any visible leaks around the turbo etc... just wondering if anyone could help me out here, is there any common problems I should be looking for? Inlet manifold? Any other boost pressure/ actuators?
Thanks, Will.
Thanks, Will.
