C250 CDi (2009 W204) Continuous Engine Problems.
AA7861
W204 2013 2.2
Can someone provide the exact part numbers of what sensors go where in the w204 please?
Steve@Avantgarde
Bristol/Somerset
Impossible. All sensors have been superceeded many times and not all sensors are the same for every vehicle.
What are you trying to find out/achieve?
AA7861
W204 2013 2.2
My car goes into limp mode, i need to identify which sensor is the turbo boost and manifold sensor along with the part numbers. The reason why i need part numbers is because, i’ve sort of changed around the sensors to get it to work, not knowing the sensors are completely different.
There are 3 of these sensors i need to know where they go and part numbers
AA7861
W204 2013 2.2
attached is the arrors of which sensors i need to know? 3 sensors, which one is boost pressure/manifold sensor? are all 3 the same or difference? which one is which please :)
Billybaggins
C250 cdi Sport 2011
Thread revival, did this original issue ever get sorted, my car hesitates at same rpm under hard acceleration
onefortheroad
uk.
You need to scan for error codes. Chances are your problem is dirty egr valve.
onefortheroad
uk.
Try injectors cleaner and maybe clean the egr.
JB9090
C250 cdi 2009
Was this problem ever cured? I've had the same problem with my 2009 c250 cdi after removing the dpf/cat and egr valve and having it remapped. Ive changed MAP and boost sensors. Had turbos inspected and came back fine. Also tried changing the engine relay as this was a fault coming up on the star machine. Had it into a few garages and had smoke tests done and other checks done and nobody can seem to get their head round the issue. Any help is appreciated TIA
Best to start a new thread for help, what problem are you having?
JB9090
C250 cdi 2009
Theres a flatspot between 3000 - 4000 rpm in 3rd gear and above when hard on the accelerator. Ive been told that theses engines are bad for that when the turbo crossovers to the 2nd stage turbo but surely that cant be right and also diagnostic computers are flagging up boost sensor faults but all boost sensors have been changed
Start a new thread, and the community will chime in where possible.
VieiraMo
Registered
Mercedes c250cdi
Há um flatspot entre 3.000 - 4.000 rpm na 3ª marcha e acima quando o acelerador está forte. Disseram-me que esses motores são ruins para isso quando o turbo passa para o turbo de 2º estágio, mas certamente isso não pode estar certo e também os computadores de diagnóstico estão sinalizando falhas no sensor de impulso, mas todos os sensores de impulso foram alterados
Tenho o Mesmo carro e o mesmo Problema
ajlsl600
france
ajlsl600
france
Ah never noticed that.!!!!!! Perhaps old stuff with no useful info shud fade away to a real benz bin??
Good idea. I think main issue is the poster who revived the 6 year old thread. Best to be a new post.
ajlsl600
france
