c250 diesel probs
B
bazza08
hi all have a c250 td and im having probs starting if i park with it pointed up hill have changed filters and pre filter and cant see any leakes any advise will be great thanks bazza08
Hello and welcome 90% of the faults are the O rings on the pipes at the filter
B
bazza08
will try these 1st thanks for your advise
Number_Cruncher
1995 W124 E300D TE
Yes, you need to change the O rings.
There are O rings at the ends of the low pressure pipes, in the fuel pre-filter, and behind the fuel shut off valve which bolts onto the side of the injector pump. In your shoes, I would renew them all.
