C250 Windows Fogging
LSD
Some novel ideas here. First thing - the a/c or c/c must be set to on which will dry the air. Sure, crank up the heater, even open a window if you feel like it, but all that will do is vapourise the moisture, which, soon as you switch off, will condense on the coldest place, ie the windows. The only way to dry is via a/c.
The air con. will dry the air if it is functioning correctly. If not, it can cause more moisture problems than it solves. Running the system conventionally with it switched off for a good time, a whole journey through warm-up and more, will show if there is a problem there, if the condensation is less when air con. is off.
Most vehicles don't have a problem when parked as described by the OP even without aircon. If the moisture isn't in the structure of the car interior (as from sodden carpets for example), it's coming from somewhere in the heating/ventilation/air conditioning system.
If moisture is pooling in the system due to inadequate drying, blocked drains etc., then it can be carried into the car interior by evaporation through open vents due to latent warmth in the system when the vehicle is parked. It then condenses on the cold surfaces in the interior as you say.
This is why I suggested making sure all vents and inlets are closed if possible when stopping: it will illiminate the system as the source of moisture, and indicate a possible problem area.
Rory
Cheshire, UK
That would be an interesting test - you could manually set the ventilation to face level and then close the vents.
I notice mine does it when I call in at my Mum's for an hour or so. It's very exposed there so perhaps the wind is driving through the car and pushing the mositure on the evaporator into the car.
drotoscope
My e350cdi coupe which is new also does this - going to dealers tomorrow as i alos reckoned that a/c drain may be blocked.
Did the original poster find a solution??
SH
mjg1066
S204 C220 CDi
Thought I'd add a quick update. My car went into the dealers last week to look at this problem.
They found a Mercedes bulletin that pointed them towards a 'dry-blow' function in the aircon that periodically blows air through the car after it's locked and left standing for a little while. The idea is that this will clear out smells etc. but it seems that in certain conditions (damp/humid etc.) this can cause all the windows to fog :-?
Dealer checked and confirmed that the recommended fix at present is to disable the function, with a longer term fix expected in June!!
So far, since having the function disabled, the windows have remained fog free :D
