1999 manual estate. Battery slowly loses charge.
As the cold weather started I assumed the battery was at fault and replaced it. The problem continues. A local auto electrician reported a steady drain but told me to take it to Mercedes as it needed their computer to diagnose the fault.
Cicely, Preston, (independent MB) had it six days and could not identify the fault.
With my very limited knowledge of car electrics and even more limited knowledge of using a multimeter I have identified a constant 0.4 amp current via fuse #30 with everything switched off.
Any help would be appreciated.
There is also another fault that has been going on for months and I hadn't thought of as being related to the above but you may be able to advise.
When the indicators are switched on there is a delay of one second or so before they work and when they are cancelled they continue to flash for another second or two. This fault also occurs with the windscreen wiper. At the same time as these symptoms began I noticed that the electric windows and the rear screen heater became hit and miss as to whether they would operate.
I apologise for my lack of knowledge and this may be a stupid question but are these items contolled by a single relay and is it possible for a relay to become 'sluggish'?
Regards, David
Regards, David
