mercedesnut
Hi, I hope some of you techies can help. I purchased a 1997 W202 (facelift model) C250TD estate 2 days ago and drove it home and parked it at night. Locked it using key fob (ithe type with a large traingular shaped fob with 2 buttons and built-in skeleton metal key. The metal key is only for manually operating the door locks). It was freezing cold (-4.5 deg C) and the alarm went off an hour later. Went out and using the key fob unset the alarm and then locked the car manually (by depressing the lock knob on each door) and using the metal key, locked the driver door. Yesterday morning, unlocked the car using the key fob and tried to start the car, but it won't start. All the ignition lights come on and the starter motor cranks the engine but it won't fire, suggesting that perhaps the immobiliser hasn't disengaged completely and has shut off the fuel supply. Have tried locking and unlocking the car using the key fob several times, but it still won't fire up. The battery may need charging up soon if I continue and so in desperation, I'm hoping that someone can advise. The MB Assist team have offered to help if I pay £184 +Vat for a callout seeing that the car is 10 yrs old! B0110cks to that. The stealer service team couldn't spare a competent engineer who could advise. The incompetent one knew even less than me which is saying something! Can anyone advise please (I'm about to go an get new batteries for the key fob just in case but my guess is that if they were the problem, the ignition wouldn't switch on and the starter motor wouldn't crank the engine, but these are desperate times requiring desperate measures and so I will try most things that don't cost an arm and a leg).
