Sorry for the long message before hand
Hi folks, desperate measures now.
Same old question so here goes,
My c270 cdi turns over, won’t fire unless I spray deodorant up the intake and then runs perfect afterwards until you turn it off then try to rest start it straight after and the same happens again.
I have replaced all fuel lines from filter forwards and all o-rings have been replaced, new cam and crank sensors fitted, HP pump has been rebuilt with all new seals and o-rings, there are no air bubbles in the lines anywhere at all and I’ve even fitted a non return valve straight after the fuel filter so it holds the pressure in the lines engine side.
I’m getting to the end of my tether with it now.
Something I read said that the in tank fuel pump should prime but I can’t hear anything when I turn the ignition on! Could that be the cause?
For it not to start straight after turning it off leads me to believe it is something so stupid but I’m at my wits end.
Any help or ideas would be greatly appreciated,
Thank in advance
Thank in advance
