JoeHorner
- Aug 21, 2022
- 2003 W203 C270CDI Elegance
Trying to get to grips with the limp mode / no limp mode on the C270 without finding someone with Star diagnostics around here (apart from main dealer....)
After the "cured / not cured / repeat" this afternoon I decided to get out and record some data thus evening.
Sure enough, it was out of limp mode again when I went out to it. Engine was cool / cold to touch but coolant sensor was reading 62 degrees C (seems a bit high after 3-4 hours standing!)
Drove for about 10-12 mins in a "spirited" way, then suddenly limp again.
The only thing that stands out on the recordings is that temp reading never went above 65 degrees and, just as limp came back it dropped 5 degrees in 45 seconds. Then rose 7 degrees in 90 secs then dropped again in about 2 mins. That seems like unfeasibly fast variations to me and, even with a stuck thermostat hovering around 62 degrees driving hard in 20 degrees ambient seems unlikely.
So, it got me thinking. Does anyone know if the CDI system is smart enough to realise it's getting unreliable temp data and limit power as a precaution?
