Arv
Hello All:
This weekend I had ONLY the right front wheel of the car on the jack with
ENGINE OFF. I had some play in the bearing, so I removed the hub cap and
tightened the bearing till the brake disc would rotate one turn or so
when I would give a light push. I was hoping that this will fix the play in the
front wheel but it didn't. I didn't want to tighten the bearing
too much for the fear of seizing it.
I put the wheel back on. I grabbed on of the tires with both hands diagonally
accross along the tread and pulled/pushed the tires in and out. I still have
play in the front wheel. I just checked the exploded view on,
http://www.detali.ru/cat/oem_mb0.asp?TP=1
but nothing seems to be obvious.
1. What could be the cause of the play?
2. Do I need to tighten the OUTSIDE bearing even more?
3. Can it be the INSIDE wheel bearing? If it is, is there any way I can
tighten it without remove the whole hub assembly?
4. How do I fix it?
Thanks a lot in advance,
Arvind.
4. How do I fix it?
Arvind.
