C280 tranny shift when cold
Status
Not open for further replies.
mjtray
Reading
Hi.
I have a 1995 C280.
When I start the car from cold, the car will shift normally from 1st to 2nd, but will only shift into 3rd once the car revs past 3000 rpm. Is this normal....it seems a bit high.
Once the car is warm, the shift into 3rd will happen at much lower revs.
Any ideas or pointers?
Cheers
Arnie
London
hello, I don't think that can be correct. Its should certainly go to 3rd and even 4th gear right away. However, I cannot hink what might be wrong.
alec
cold starts
Most automatics are programmed to hold on to the lower gears for longer when cold in order to warm up the cat converter faster.
Alec
jaymanek
Nuneaton, UK
www.mercland.com
this is a feature that they had in those boxes. You can have it deprogrammed at the dealer. I hated it on my E220, but never bothered to get it changed.
M
mjtray
Reading
Thanks for your responses........I had a suspicion that this may be the case.
Looks as if I will just have to learn to live with it.
Many thanks
Status
