c320 2001 p0300 p0301 p0302 p0303
harvey
london
2001 c320 auto
can any one help .my car drives fine until i accelerate hard then engine light comes on.have changed plugs but no change
5pares
Suffolk
E320cdi
You'll need to supply moreinfo if poss?Its a 112 engine i presume,misfire could be due to plug leads,or air mass causing lean mixture.
Hello and welcome to the forum:D
As 5pares above try unplugging the MAF and try the car,it may be lumpy on idle, but try it to see if the power comes back
Cole@MBS
www.mbssouthampton.co.uk
Sounds like another "water in the fuel rail" fault to me, seeing this a lot now!!
H
harvey
london
2001 c320 auto
thanks for the quick reply, will try maf tomorrow and get back to you
Cole@MBS
It gets in via the tanks at the fuel stations, the 320 has a one way rail which dont return to the tank, so any muck/water has no-where to bleed of to!!
H
harvey
london
2001 c320 auto
what would the best way to sort out this problem
Cole@MBS
The fuel rail has to be removed and cleaned out with carb cleaner, new seals needed when refitting the rail, grease on all seals so they dont get pinched as they go back on!
