cryomorph
- Feb 15, 2024
- 2008, W204, C320 CDI SPORT
Hi everyone,
I have a 2008, W204, C320 CDI Sport with the 3.0l V6, OM642.960 engine.
I have recently had the turbo replaced with a recon unit by the second hand car dealer under warranty. This was due to damaged turbo vanes due to a very small piece of rubber coming loose on the piping connecting to the turbo.
Since having the car back, whenever I try and accelerate, the car will boost very hard for a second, then start jerking back and fourth, before finally going into limp mode where power is very restricted and the kick down function will not work.
I have heard this could be a faulty turbo actuator. The actuator 'G number' on the car at the moment is G-88 and the turbo is a Garrett 770895-8 (that's the code on the turbo)
I am concerned they have taken a short cut with the turbo replacement and perhaps put the wrong model in?
There are no codes showing on STAR weirdly, the indie Mercedes specialist tech was insinuating the engine had been mapped previously (that was his explanation for the way the car was driving) and didn't seem particularly interested in trying to fact find when I had them inspect it.
I have since ordered a new actuator from eBay (G-88) and a back pressure sensor, probably in vain, but I am desperate at this point as the car is un-drivable nearly.
Other than this issue, the car seems fine, there are no strange noises or knocking coming from the engine and it starts straight away.
Any ideas?
Thank you.
EDIT: Before the new turbo was put in, I wasn't having this issue, just a whining sound coming from the turbo, which is when the damage to the vanes was discovered and subsequently replaced with the recon unit.
Any ideas?
Thank you.
