C320 Front LH indicator lamp
RIB
New Registration
Hi, I've recently had a fault with an indicator lamp and so I replaced it. However the fault still existed so I tried inspect the fuse. I found that there is no fuse for the front indicators and the fault remains! Can anybody advise me to what I should be doing? Thanks.
Ellsy Tanners
Mars
You need to fit a modified bulb holder. the contacts will have burnt out. its only about £15 quid. any merc parts dept will know wot you need. its simple to fit. use pin 1 on the main headlamp contector block. its pretty self explanitery!!
Ellsy Tanners
Mars
This is a extremely common fault, with the 203.
a simple fix for a competent DIY mechanic.
Sorry about my post yours came up with the solution while I was writing.
I have removed it
