Typical that the metal key in fob was broke, git a replacement made and done now, thanksHello and welcome
Use the metal key in the keyhole by the boot release handle. You may need to clean and lubricate the lock if you’ve not used it before.
Always get 2 keys with the car and always check that the emergency metal keys work…Typical that the metal key in fob was broke, git a replacement made and done now, thanks
Thanks again, I've just created a new post, as my command screen keeps turning off and a high pitch noise sounds, no stereo controls etc workAlways get 2 keys with the car and always check that the emergency metal keys work…(Clean, lube and use the lock in the door and boot every 6 months)
