Reddy
- Jul 7, 2019
- Mercedes C350 CDi BlueEfficiency 2011
Over the last few weeks I have started having problems again with my 2011 C350 CDi Auto (W204). It is running poorly - higher revs before gear changes, unsteady engine revs around 1200-1500 rpm, lack of power. I now have a EML on and my cheap obd reader is reporting P0404 and P0405 codes.
I thought I would start with the EGR valve since both these codes relate to this. I removed it and although it wasn't as dirty and clogged as I expected (and hoped), I cleaned it, checked the arm was free and opened and closed the valve as expected. I couldn't check the electrical side of it as I didn't have the tools or wiring diagrams.
I replaced the valve in the car, hopeful it had cured the problem. Initially, all seemed ok until the engine got up to temperature, then the issues returned, along with the P0404 and P0405 codes.
My next step is to replace the EGR valve, but I have read online that people suggest unplugging the EGR valve entirely and seeing how the engine runs. I did this, but the performance did not improve and the codes (plus some additional ones) were still being triggered. Before I spend the £££s to replace the valve - could this indicate the EGR valve may not in fact be the issue after all and the fault could be elsewhere?
Any help or advice would be greatly appreciated.
thanks
David
thanks
David
