They should do that as part of the service buddy . But it would never hurt to mention it when you drop it off if it's going to bother you
they will probably only drop the oil and fit a new filter so 350 quid isn't cheap really
When you go to sell 'Main dealer service history' is a big positive
Get the most out of my money i suppose!
I know i know, but what can i do eh? When you go to sell 'Main dealer service history' is a big positive
Putting 2 new tyres on the front before it goes in, cant imagine how much they would charge! £402 for 2 front conti's (run flats) fitted - 225 40 r19 v xl
To put it into context when I put my details into that link my next service will be:
"A" Service costing £243.61
Which consists of.....
Somewhat of a p**s take on Air filters as they cost £65 to buy direct from Newcastle MB and take 10 mins to change
Even more of a bargain on air filters when they appear on the invoice, but upon checking the "new" filters, they appear decidedly "old"...!
At which point you have them over a barrel - Why not penetrate?
Which consists of:
Change engine oil and oil filter (not applicable for electric vehicles)
Check charging cable and vehicle socket for mechanical damage (Hybrid & Electric)
Check brake fluid level
Correct and note down tyre pressure
Check/correct spare tyre pressure (equipment specific)
Check TIREFIT tyre sealant (equipment specific)
Check first aid kit
Check luggage compartment illumination for proper operation
Check/correct windcreen washer fluid
Check lamps in the instrument cluster and interior illumination for proper operation
Check ex-factory driving aids (equipment specific)
Fill up or replace vial of perfume atomizer (equipment specific)
Fill up Ad®Blue tank (equipment specific, after consultation with customer)
Check coolant level
Check all visible parts in engine compartment for damage and leaks
Check visible area of auxiliary belt for wear (if applicable)
Check all visible parts of vehicle underside for damage and leaks
Check condition of steering and tie rods
Check condition of front axle and front axle ball joints
Check condition of propeller shaft and flex disks
Check condition of rear axle and rear axle ball joints
Check condition of suspension struts or shock absorbers and springs
Check tyres for damage and crack formation
PLUS
Brake Fluid £98.59
Air Filters £165.84
Fuel Filter £184.26
Total of £692.30
I agree, people who don't really know cars will always appreciate main dealer servicing. I did when I bought mine. I've learned a lot from this forum and now take all the 'recommended work' to MBS in Southampton but by having the basic service done with the main dealer, I preserve mobilo cover. Probably a bit expensive but I'm keeping a foot in each camp.When you go to sell 'Main dealer service history' is a big positive
