MilesMurphy
- Sep 16, 2014
- Location
- Bristol
- CLS55 AMG 2005 5.5 Supercharged- C43 AMG 1998 4.3
Hi All,
I have bought a project c43 with a 55 lump from an s class in it. I ran some tests to crank the engine. I found that the starter works fine and the engine turns fine too. What I'm having issues with is I cant start the car from the key, although it did spin the starter motor from the key and a slight crank the first time. Now I get a click sound from a reply and nothing.
Could it be a relay that's gone, if so where? Or has the immobiliser kicked in for some reason.
The engine loom is from the 55, its been slightly chopped by the last person so I'm after a base level so I know what changes have been made. If anyone knows the closest loom that can match the 43 original (A202 540 71 07) loom that would be great as merc no longer sell it.
I double checked the starter and it fires up using a direct method to activate it. But when trying from the key I get nothing.
I have charged the battery and will give it another go.
I have also removed the fuel pump fuse for the moment as i just want to crank it not start it.
Apart from that everything works in the cars.
Miles
Miles
