yinujim
- Dec 21, 2015
- Location
- Essex
- 92' 500SL, 04' E500 Estate
Hi can anyone tell me how to calculate the inclination angle values? The car is sitting very low after some suspension work. Plus the nsr is quite a bit lower than the osr. I do know the nsr air spring leaks overnight but if I can get the correct ride height first.
I'm using a Otofix scanner which is a rebranded Autel but it seems to follow the Star procedure. I also know the low right height will exaggerate the camber but the front wheels seem to have quite an extreme camber angle. More so on the osf than nsf.
