caliper guide pin bolt
LeeW
Hi,can anyone tell me if the caliper guide pin bolts need replacing when renewing
brake pads(C250D)?Thanx Lee.
dava
The Toon
No, just make sure they are free and reassemble using cooperslip.
MB say that new bolts should be fitted, some do some do not change them, the bolts that hold the caliper to the stub axle should at least have locking compound applied, the actual pins it depend in their condition, I seldom change them it they are a tight fit, the same with the sensor wires, if they have not been in contact with the disc and are in good condition then I do not replace those either, its up to you in the end
C220GJS
Shotts, Scotland.
1995 W202 C220 Elegance
These bolts are supposed to be replaced but may be reused with locking compound on the threads, do not use "Copaslip" anywhere near these threads !!!.
L
LeeW
Thanks fellas,I reused the bolts they tightened up well enough.Did not need copaslip as pads came with sachet of specialist anti squeal grease.Everything seems to be working ok so far!!
chizel
Banned
if my memory serves me right the Mercedes benz brake calliper slides (guide pins) are held in place by two 10mm allen bolts. they will be sunken inside rubber sleeves and will be capped so you will need to remove the caps first which you do so by prising them out of the ends. make sure you replace the plastic caps otherwise you will end up with seized slides.
Mercedes-2010
Staffordshire GB
Mercedes C350 AMG Sport (2013)
FAO Malcolm
Malcolm, can you please put an exploded view piccy on here of the caliper and hub assembly fixings?
Cheers Dave
