m6dtt
- Aug 3, 2006
- Age
- 57
- E350 Sport Bluefficiency 2011
Can you please let me know your opinion on this matter ...
I had a new key cut for my E320 (w124 1994 75000 miles on clock & mint car) recently. The key was not cut accurately. The key was over cut in some places and uder cut in others. Visually different.
When I put the newly cut key in the ignition the key went in but it would not turn the ignition. The key refused to then come out of the ignition!! I ended up having to have the whole ignition stripped out as the key got jammed, infact the barrel would not even release when the two pins were used which is the normal way to take out a barrel.
The strip out job was done by a specialist MB workshop.
Can you please tell me if you think a badly cut key could get jammed as it did in my car? I wish I had known before or I'd never had taken the risk of inserting a badly made key but had I known. I found out too late!!
I would be extremely grateful if you could add your thoughts.
Thanks.
Thanks.
