Can anyone decipher this fault code?
Brian23
EClass
Hi this is a Icarsoft, Parktronic fault code on a 2006 R170 200 SLK. Exactly as on the fault reader.
the driver a failure, even though PTS is not defective (eg. Car Wash, Pnumatic drill or Traffic Light induction loops).
This is the only code on the parktronic. I know what I THINK that it is, but your imput would be good.
onefortheroad
uk.
A proper scan will say things like offside inside sensor . Or nearside outside sensor . Faults .... you can also see live data in the parktronic section.
Botus
S500/2010/500
if you follow Jag's, Nissan's, Honda's and the odd mobile traffic light they can make the parking sensor throw their teddies... it's because between them one idiot manufacturer must be using the wrong frequency ( I don't know which)
for some stupid reason Merc's store these incidents as a fault - just delete it - although its likely it can be back as soon as you drive the car
I would say that's a made up description that as you have found is more or less meaningless trash - there is a real fault code and description for it - but that's not it
B
Brian23
EClass
Yes, but it doesn't. It says this.
B
Brian23
EClass
Yes any other fault code on the reader gives a codes and description, but this section (Parktronic) Doesn't. Deleted it, but as you say, it has now come back.
onefortheroad
uk.
Which icarsoft unit did you use.
Botus
S500/2010/500
every time you are in traffic near a Jag or a Honda the car can have a melt down... mine does it regularly and for no sensible reason its stored as a genuine fault
its accompanied on mine with a long beep and an orange (maybe red) message on the cluster saying parking assistance not available - it can be really irritating if they don't get away and the car just does it over and over for miles
do you have hidden parking sensors? the early w221 has them front and rear but it looks just a plain bumper, within 2 years they all went to visible ones (I suspect these are less troublesome)
joderest
ML270 2003
someone i knew had a landrover (think it was a Freelander) with parking sensors. When someone rang his cordless front door bell, the system flashed and logged a fault !!! (they may have been after market ones)
Work that out
bembo449
gainsborough , lincolnshire
This is proper spaced out shiz , the stuff in crime novels , cars that cock up other cars :p:p:p:p:p just by being near them.it sets off thoughts of when my LR has irritated the shiz out of me when parking and i just brushed it off as trait :p
Discovery’s used to be a nightmare with immobilisers, if you drove one to Italy and parked close to a Police station you could never disable the immobiliser as the Policia Radio would overwhelm the receiver front end.
Similar with the alarms on the Escort van, if you took them to a big transmission station you’d have to get it towed off site before you could start it.
The frequencies are reused often and car systems are almost always 2nd or 3rd users.
Botus
S500/2010/500
check this one out....
https://www.wired.com/2015/09/gm-took-5-years-fix-full-takeover-hack-millions-onstar-cars/
When a pair of security researchers showed they could hack a Jeep over the internet in 2015 to hijack its brakes and transmission, Chrysler issues a software fix before the research was even made public after the NTSC issued a 1.4 million vehicle recall, however GM knew 5 years earlier this bug was in the cars but choose to ignore till the specific model impacted was leaked
ajlsl600
france
rely on makers to be sneaky and not honest...
B
Brian23
EClass
Thank you
B
Brian23
EClass
I have just deleted the fault code from the car again and everything has started working again. So fingers crossed, until I pass another car or traffic lights which may effect them.
