Can anyone recommend a good multimeter?
AbeM
Edinburgh
E320 CDI Sport Estate
Probably don't need a top of the range number. Ease of use for someone of limited technical ability would be a good thing to factor in to any recommendation.
I probably could just go into Screwfix or Halfords and buy something. I just know that there is much wisdom and knowledge on this forum I'd be daft not to ask first.
I would buy on Ebay, having a 10amp DC is nice, you can get a good one for not much money, the ones Screwfix sell are on Ebay much cheaper, no need to pay more than £10,,, take a look and post up any links and perhaps I can advise you.
The Auto ranging versions are good if you are unsure of what you are measuring, but they cost more, if you are using it a lot, then they are rather slow to use.
I have 11 different ones
DY2
Bexleyheath, Kent
W211 2003 E320 Cdi Automatic
I have the cheap Yellow multimeter from Halfords...Works well.
If?? cost is no object FLUKE takes a lot of beating. http://uk.rs-online.com/web/p/digital-multimeters/6161460/ Otherwise Maplins have a good selection http://www.maplin.co.uk/productsearch?criteria=multimeter Make sure you get one with a large numeric display that's easy to read.
The average person does not need a Fluke, all the cheap ones are just as accurate, I have used micro amps and micro volts for the best part of my life but no use for car use. I have a £1500 Fluke that is a pain in the back side and my £16 meters are just as accurate.
For home and car use you do not need a super meter, on a car you are often just looking for around 12v at a certain point, the resistance and continuity ranges are fine for checking bulbs and fuses.
Miffy
Bromley, London
CLK 320 CAB Elegance C208
I have a fluke 77 and a £5 maplin cheapo. Both measure V ac/dc just as good as the other
And not so heart breaking when you drive over a £5 version, though one of mine still works after both wheels went over it;)
cleverdicky
MB
I posted a link to a good late model AVO listed on ebay a few weeks back.
OK a brick sh*t house of a meter, but what a tool.
Think it went for about ten quid
benz chap
Money to blow and want a nice toy from a quality manufacturer?....buy a base model Fluke. Not a 1500 quid unit!
Not a lot to spend and just need functionality? - 10 to 20 quid will buy you all you need.
Always the danger that an inexperienced user could miss read it
Bolide
www.w124.co.uk
BMW 525 Diesel Touring
Two things every multimeter should have: auto power off (obvious) and auto-ranging (not so obvious)
Autoranging means the meter works out the voltage (or current, etc) and displays it in appropriate units without you selecting a range
The other thing that multimeters never have is a pair of croc clips so you can keep your hands free. So buy a pair of spare generic leads, cut the ends off, extend them and fit insulated croc clips. I recommend a small one for the positive and a big one for the negative so you can grab a bolt, etc for an earth
Nick Froome
mersum1es
Finland
I have clamp-type multimeter like this, only problem that measuring ranges are pretty high = not good reolution/accuracy in small voltage/currents. Then I also bought blade fuse adapter so I can measure smaller currents over the fuse with 'conventional' more accurate multimeter...
Nick Froome
Auto ranging are fine if you do not know what you are doing, for the experienced they are far too slow. When checking on a car all you need is the 20v dc range, and 99% have just that.
I have a good one that resolves down to 1ma DC and that cost just £45 the details are in my DIY and car testing.
It is the only one on the market like it and a fraction of the price from any other maker from CPC,it can also be used as a multi meter
www.ckinsurance.co.uk
