clk2000
- Jan 31, 2019
- CLK230/A208/2000
- Thread Starter
- Thread starter
- #21
Here we are, back again ...
Ok, I have had a chance to have another look at this car. I swapped out the recirculating air flap and the self same issue occurs.
Same error code: P2004-001 High pressure sensor Signal - Short circuit to plus/open circuit (P0108)
Same scenario also .. fault code comes up, erase code, start car - no code. Restart car and code comes back. Rinse and repeat.
All voltages checked and all ok on all circuits. Swapped out both sensors on circuit, no difference.
Swapped out air flap, no difference. ECU change, no difference.
I'm at the end of the line with this one. The only reason I have to get this sorted is if something is wrong with the MAP circuit, then the fueling goes haywire and this won't get an MOT due to emissions. Carsoft 7.4 is supposedly the closest to STAR on these cars and live data even for the Lambda sensors is within range. Should I just ignore this fault and take CO readings instead ?
Any further suggestions ?
