d215yq
- Mar 28, 2008
- Age
- 40
- Location
- Valencia, Spain
- 1987 W124 300D 280k miles
I think i may have found where water sometimes leaks out at the front of the car: finally got round to replacing a sidelight (had to hard wire it in as bulb holder corroded but no problems, works fine) to find there's almost an inch of water in the bottom of the LH headlight cluster. As the lens is cracked and it's clearly no longer sealed can i drill a hole in the bottom of the plastic headlight unit to let the water out?
With the climate here things dry very quick so should rarely be condensation but now i see why there has been condesnation even after 30 days without rain! Yes I know I should replace it but that is more expensive than you would think...and can't be good for the vacuum line to be sitting in this puddle of water...
