nickh
- Aug 2, 2002
Hi.
Does anyone know if I can replace the viscous fan on my w124 230e with an electric one? - I found with this hot weather when the viscous fan cuts in with the air con on, the engine speed drops right down and the engine struggles with both running, then the air con eventualy gives up as the rpm is not stable..
This happens only when stck in traffic after about 30 mins or so, I found with the aircon on the aircon fan is able to keep the car a little cooler for longer before the viscous one cuts in.
