Can I strip and rebuild PAS Pump W124??
Waft
Cambridgeshire
1993 E220 Sportline Coupe
Hello!!
My PAS pump sounds "bearingy" while listening close up,and has begun getting heavy now.
Also,I changed the fluid about 6 months ago and already it's black.I used normal ATF,Dexron 3.
Can I strip and rebuild the pump??
Is there a schematic someone could perhaps post,so I can see a full breakdown.
Once I have torque settings,I'm more than capable of replacing components,O-Rings etc. In fact I'd quite enjoy an overhaul over Christmas in the workshop :D
TIA
Steve
william28ho
Hi - you can get a good second hand pas pump from a scrapyard, saves a lot of time.
I hope this has help
As the above post,,, there are no Mercedes instruction anywhere for this
mikestrivens
Stockport
If I had the time, and knowledge, I'd be inclined to get a good 2nd hand one to put in and then dismantle the one that is on the way out. This way one would learn about the pump and whether it can be refurbished whilst still having one on the car that works. That way it doesn't matter if it can't be fixed and you still have the car on the road. If it can be fixed then you have a spare for later. I used to do this with Ford parts when I was a student - saved quite a lot of money in the long run and learnt a lot. When I have more time on my handss I'd do it again but the components have become a lot more complex nowadays.
So true Mike and that was the way I lived some time ago and a learning curve into the bargain :D:D
Frontstep
T210 320cdi
I suggest a search on Youtube I have seen a few pump rebuilds of other makes and models.
Access to pullers and or a press would seem a good move there is nothing complicated in them.
kth286
E320 Coupe 95
the pump is suprisingly easy and has few parts in the rebuild kit.
was about £13 last time.
BUT you need to research which pump you have as there are several
versions.
grober
Scotland
W204 C200cdi estate
versions.
IRRC htere should be an identity plate on the pump somewhere which should help?
syncropaddy
Sunny south east
.... too many cars!
The guts of those pumps look like the ones on VW power steering systems which are ZF units
