Can I use Comma CHF1L Central Hydraulic Fluid CHF 11S - 1 litre
H7PTW
Derby
SL500 R230
Just checking the Comma CHF fluid is ok to top up the ABC fluid?
I need to use the car and can buy this from Halford or Amazon Prime next day.
Gazwould
C250 CDI
Is the spec required CHF11S ?
Yes CHF111s is the correct spec.
As long as that is what you get then it's fine.
Halfords stock it if that helps.
Some Citroen's but not all use CHF111s.
The others use LDS or LHM.
You cannot mix them!
Gazwould
C250 CDI
Comma MVCHF is your friend .
Correction to my above posts where I typed chf111s should be chf11s.
H7PTW
H7PTW
Derby
SL500 R230
Thanks for your help, purchased some today.
