The previous owner of our r230 did exactly that.I've got 275/30/19 rear tyres on my E class. Is it possible to go to 275/35/19 slightly bigger sidewalls?
My fronts are already a different size (factory spec)You can do, but you’ll have to alter the fronts as well otherwise you’ll most likely get an ABS/ESP error as there will be a speed imbalance between the axels.
Also the Speedo reading will change due to the increased tyre diameter.
I’m presuming it’s for comfort, find some 18“ or preferably 17” wheels and tyres. You’re back and suspension will thank you...
The point is you need to increase both front and rear. The abs, cruise, tpms and ESP all measure the speed of each wheel to determine if there is an issue and react accordingly.My fronts are already a different size (factory spec)
What e class do you have? If its w212 or w213 it should standard be 275/35/19 for the rears and 245/40/19 for the fronts.I've got 275/30/19 rear tyres on my E class. Is it possible to go to 275/35/19 slightly bigger sidewalls?
Assuming your speedo isn't already reading 5% low like most are.Don't forget that your speed/distance etc will be around 4% out.
At an indicated 70 you will actually be at 73 ish
Sent from my ONEPLUS A5010 using Tapatalk
I went to 225/45/17 all-round on the SLC with Nokian all season tyres.Interesting reply LK - I have proper 225/45 R17 Xclimates on the front of my S204 but cannot get 245/40 Xclimates (or alternative all weather tyres ) for the rear, seems either 235/45 or 240/45's are available. Same problem potentially on the SLK, although I have new Goodyears (summer tyres) on the fronts so will only be looking some time to replace the hard Hangkook rears on that car.
On our last SLK200K we had the staggered set up on the summer wheels & all the same size on the winter wheels, never noticed any difference. Our first SLK200K had 205/55/16 all around.Have thought about that, but wonder about the effect of reducing the rear tyre width by 20mm of road contact - as that's where the car puts the power down. I'm not a boy racer or track fiend, so possible would not notice - but also wonder about putting 225's on the wider rear rims as both my cars have staggered 17" set-up from new.
The standard tyres on my S203 were also 205/55R16 so no issues with 225 all round.Have thought about that, but wonder about the effect of reducing the rear tyre width by 20mm of road contact - as that's where the car puts the power down. I'm not a boy racer or track fiend, so possible would not notice - but also wonder about putting 225's on the wider rear rims as both my cars have staggered 17" set-up from new.
