stumo
- Sep 4, 2008
- Location
- VIC, Australia
- ML270 | ML55 | Sprinter 316 | UNIMOG 424
I got my carsoft compatable (proper) multiplexer and CS 7.4 the other day. It all works really well, except for the ESP and ABS systems.
So it cannot find my ESP system at all, and the ABS is reporting back with invalid values. It can connect to the BAS (but only when I connect directly to pin 9 of my OBD port (all 3 of these systems are supposed to be on pin 9 of OBD according to my 2008 WIS)).
The BAS directly, and all other systems on the car via the multiplexer, all seem to be working fine. Its just the ABS and ESP that aren't working for me. The AAM test gave back several stored errors about low voltage and CAN comms problems.
I think either way the multiplexer will have to be replaced since it cannot connect to the BAS through the multiplexed connection. But to me the ABS and ESP thing is more important to get sorted at the moment, and may be the difference between a replacement or money back instead. So I would greatly appreciate any feedback about the following 2 things...
1. Does anyone have any tips for what I should do now about the ABS and ESP systems. I don't actually have any live errors or error status lights up on the dash of the car (MY2002). But these 2 systems are fairly common sources of issues, so it is kind of important to have a tool that can interface with them. I'm thinking maybe cleaning the connectors at each module would be a good start?
2. If possible I would also like someone to confirm that the ESP and ABS tests in carsoft do actually work with the 2002 (facelift) W163 ML (and are on pin 9 of the OBDII port).
Thanks for reading. By the way I did post this on a different (US) forum - not naming any names, but I'm slowly beginning to realise there is far more expertise on this forum.
