cant open boot! cant charge battery!
mordwest
hi,
unfortuneatly i have had my clk 320 in my garage for a few months and been unable to drive it. I can now bring it back out but the battery is completley flat. There isnt even enough charge to use my key to pop open the boot! the metal key will open the doors but will not turn in the boot so i cannot get to the battery! I am desperate to get driving it again! i have got a battery charger at the ready! any ideas on how i can get to the battery?
hope someone can come up with a miracle!
karen
If you open the bonnet,,there is a small plastic cover that opens up near the bulk head,,you can join the battery charger over the connections there and that will let the central locking work,,,you can then charge the battery in the boot
M
mordwest
excellant will give it a try (after i've painted my nails)! only jokin! will go and ask my neighbour to find the bulk head 4 me and will connect the charger!
thanx again
It is just behind the fuse box,,when your nails are dry :D
M
mordwest
ok i am progressing!
i have found a blue 4 pin plug with a brown wire, a yellow/white wire, yellow/grey wire and a smaller yellow/brown wire. what do i connect the charge too? black grip of charger to the brown wire i guess, but then i get stuck!
Cole@MBS
www.mbssouthampton.co.uk
Next to the strut n/s theres a black box with two fuses inside, neg to chassis, pos to one of the fuses!
If I lived closer I would come and do it for you:cool::(
M
mordwest
whats a strut?
might give up 4 2nite!!!!
just had an idea that i might be best to take it to my local merc specialist in truro but if i could do that i wouldnt have the problem!!!! div!
Somewhere on here there is a photo of it,,,I will try and find it for you
M
mordwest
thanku so much for ur help & time, i will get back on the case 2moro and hopefully get drivin!
karen
