Car fob Single Button Keyfob Resync - Key from Alternate Car
gerrado
Mercedes 1996 C200 Mercedes 2006 180 Kompressor
Good evening,
I have read many threads reference the key fobs and resynchronising the single button keyfob with the car. (Point at rear view....).
However,
One of the keys I have that was taped up, the button has actually fell off the board from the solder points. I am going to attempt to resolder this but......
In the meantime I have purchased a Key from Ebay with the board intact etc.
I have replaced the blade key in this and attempted to resync / "reprogram" the key fob to no avail.
I have heard that sometimes it can be tricky and just to persevere with the sync method and it will work.
Can someone please tell me if I am wasting my time? I was under the impression this would / has worked from reading forums.
To be clear. It is a key from ebay, from a alternate Mercedes but the fob should be the same part.
!996 C200 Mercedes
Any advice would be appreciated.
Cheers
AMGeed
Poole, Dorset
S204 C180K
You are wasting your time. A key from a different car cannot be reprogrammed to work in your car.
As per above, it won’t work.
Use the buttons and case from the eBay key to repair your key (use your board and internals)
G
gerrado
OK thanks, it was worth a gamble.
Just out of interest is it an expensive job for the reprogram if I have the key?
I am of course going to find someone with more nimble hands to attempt to solder the other key in the meantime.
Cheers!
Gerrardo, unfortunately as mentioned above.
Mercedes only I am afraid, due to the age of the car you will be lucky.
G
gerrado
OK mate, appreciate the reply.
Cheers!
