JLT
- Apr 1, 2020
- Location
- Bradford on Avon, Wilts
- W204 2008 C220 CDI Estate
Firstly, please let me apologise for my 1st post being a plea for help, but I'm a key worker and need my car daily, but I'm having issues that I need to resolve.
Car is a 2008 W204 C220 CDI with the 646 engine, 5 speed auto, no DPF.
Started about 5 days or so ago. Idle on start was poor, (bouncing around the idle point), almost like rough running, but add revs though, and it feels fine. The throttle response is worse, economy down by about 5-6mpg, but strangely feels faster under acceleration. It is slowly getting worse on start idle and the throttle response is becoming more tempremental.
I've used the great wealth of knowledge here to check for the obvious; no vacuum leaks, no fuel leaks, injectors seem fine - no chuffing or Black Death, air filter is only a month old and still nice and clean. I've plugged in my diagnostic tool, no DTC, but on live data I noticed the MAF is showing airflow that seems quite a bit out of spec (according to google) and the manifold pressure a little high - See pictures and graphs below.
I don't know the CDI engine that well; does 15g/s at idle at 90g/s 2500rpm sound like a faulty MAF and is it as simple as replacing it, or is there other reasons the MAF and MAP can over read?
Any help, advise or thoughts gratefully received, I need to use the car most days and most garages are not open, so hoping to get this resolved.
James
James
